Sambanks007
I am looking for a John Deere mid pump for a John Deere backhoe 510-C.
According to the introduction in the JD parts book for the 510, your serial number tag is for a 510. Up to serial number 193045 the C means diesel engine. As I mentioned there can be confusion caused by the suffix letter, 510C is a later model.Here is the serial number
I have been to 2 different John Deere and they both said that it is discontinued it is a piston pump not a gear pump.
I would like to find a rebuild kit or a reman pump.
If you know anybody that can rebuild it or has a reman pump let me know.
Let me know.
Thank you very much
Good morning Jim,May I ask what was reasoning for removing front hyd pump? If anything other than a hyd leak what type hyd diagnostic procedures were performed prior to pump removal?
If another front hyd pump is needed Kin-Tec has good reputation. https://kin-tecindustries.com/products/ar101288/
Another hyd pump source is https://www.abilenemachine.com/hydraulic-pump
YesThank you for posting your photos. Does your 510C also have a front hyd pump?
You’re welcome and yes it doesThank you for posting your photos. Does your 510C also have a front hyd pump?
I have clean the sump screen, three new filters, two new pumps, fresh hydraulic fluid flush the system, freshened it up again check the lines i’m getting pressure from the transmission pump out of the side of the transmission I checked the PTO pressure port I’m getting pressure and fluid out of there it just is not going up to the front pump it’s a steel line coming off of there going to the front pumpdo you have steering? And some hydraulic function. Or absolutely nothing? Have you changed both hydraulic filters and the screen below?
