stevenmhardy
I have question thought I would see if someone knew answer to it.
I am adding some pictures, but I removed all bolts and springs for slip disk but I can't get the PTO shaft off of the slip disk I thought maybe that thing in center that's hollow was a pin but i can't tap it out, I could drill it out, but I am not even sure if that's pin holding it on.
there two black t pin I think their shear pins not sure they seem to be lose but you can't pull them out and if you do, they don't pop back in I think they're supposed to be spring on them that pulls them or holds them into position if so that does not seem to work.
but I cant see to be ablet o slide that PTO arm off of the slip disk the green part on front.
