trross2001
New member and happy to be on board. Currently I’m rebuilding a John Deere R pony motor. Albert at Renaissance is handling the crank turn or replacement.
My question is with the main bushings and specifically with the removable main bearing bushing plate at the front of the motor. The main shell has a 360 degree cut through the center, which would lead me to believe that the oil galley hole in the bushing may not need to be oriented with a particular hole in the main casting due to oil pressure “finding” the hole. it should be noted that this main casting has three machined oil galley holes in the shell of the race. The service manual does not mention anything about this particular bushing and the pictures orient it straight up towards the cam bearing. Anyone drifted these bushings in and had a thought process? The rear bushing on the flywheel side looks to have one hole at the top of the journal and I will align that one accordingly. Thanks.
