hello, my machine has developed a problem suddenly where the blade will no longer stay in the air in the center hold position with
the machine running, drops in a few seconds. the blade will hold the machine off the ground when pushed down so the problem is
only in one direction.
i suspect the problem is in the control valve as i can hear fluid bypassing in the center hold position. i have rebuilt the lift
spool with new orings, u-seals and dust seal but the result was no change.
does anyone have an idea on where to check to solve the problem?
thanks
thanks
