Long 360 4wd front tire size
The front tire size on a 4x4 is going to depend on the rear tire size. They need to be in proportion to each other so they both pull at close to the same speed in 4x4.
Tractordata lists stock tire sizes, but I went and checked, and they don't have that information for the 4x4 version.
HOWEVER, they do have tire sizes for the 2360, which is the follow-up model to the 360. Assuming the tractors are mechanically similar/identical:
Yes, I couldn’t find anything listed for the 360 4wd but never thought to try the 2360. Pretty sure they’d be the same. Thank you! Looking at one that has the incorrect front wheels and tires on it so trying to figure out what l would need to do. Thanks!!
Big planetary hub. Also has 13.6/24 rears unlike the 12.4/28 that tractor data shows. Do you have a link for the auction?
OP I have a Long 2510DTC, it's been a good utility tractor needing few repairs.
I've heard they're unsupported for major parts and being metric Ford parts won't interchange. Someone correct me please if I'm wrong. Just a FYI.
