Duallymike88
Hello, I'm new here but obviously having issues with my 1975 Massey 1155. I've done a lot of digging into research on this topic and did a few tests myself without a book so far.
the tractor is going to be slowly turned into a pulling tractor as time goes on.
to start out i picked this thing up and went to drive it home 3 miles and the tractor slipped bad in road gear. i then turned multi power off and got it home. 3 point will go up but won't go down. pto shaft spins but i have nothing to hook it to. I then drained the trans and cleaned the screen then changed the hydro filter on the nose. After that i mad a hydro test gauge and tested multi power ports on top of trans. i don't know what ports for what are but I had the gauge on them all. let's say around 175 psi to 265psi while flipping lever back and forth and revving engine to around 2100rpm " fitting on right side of cover towards back" would this be a clutch pack failure? I am splitting the tractor at some point this week. making my own splitting stand "rails" and i should have it apart in a few days.
