Chevytrucks
i’ve got a Massey 135 with the 3 cylinder perkins gas engine that I’m having issues with. It will turn over and try to start but will never take off and run. Sometimes it’ll barely run for 10-15 seconds then die. Acts like the throttle is too low but you can move it anywhere and it does the same thing. It’s getting plenty of spark at the points and at the spark plugs. Carb was just cleaned/rebuilt with no change. Has fresh gas and it’s getting to the carb. After turning the engine offer a couple times gas runs out the breather side of the carb. I’m assuming where it’s dumping gas and not starting. Thinking possibly a governor issue? Any help would be greatly appreciated. It has 120psi compression on all 3 cylinders.
