Hate to keep bothering all you fine folks
about my 265 but the diesel thing is new
to me. I have 5 tractors and they're all
gas. Lol. Anyway, I'm trying to line up
parts and understand why I keep running
out of fuel. Ran flawless before I took
the fuel filter off to see why it was
leaking around the top o ring. Hasn't run
right since. Old farmer out the road says
it mat be sucking air in around the
filter. He said just get a new filter and
o rings and be done with it. Ok. No
problem. Here's the new issue. My parts
book shows a top head, filter, glass bowl
and stem. My tractor doesn't have a glass
bowl. My bottom is a pot metal cap with a
stud. Cav top head with 3 holes down
through, one bolt to tighten the filter
stem, one bleeder bolt and one line coming
back from the injectors. I'd like the
glass bowl back on it but want to make
sure I buy the right parts. The stem seems
to be hard to find and they make several
different bowls. A replacement assembly
isn't cav style and only has a bleeder
screw and a stem bolt and no place for a
return line from the injectors. The part
number stamped in my bottom plate is
7111/412. My filter is about 5 inches tall
and seems like the filter for the glass
bowl setup is only like 3 inches tall.
Need help with part numbers or where to
find the right parts. Thanks in advance
