1974 mf135 Perkins diesel multi power
I got this tractor from an individual that had just replaced the clutch. The tractor was damaged in a fire and I am trying to get it back in shape, rear main seal was leaking so I split the tractor and am finding an unusual situation for me anyway, with the clutch. all info I find does not show the clutch that was in it. The pto shaft does not go into a clutch disc but the pressure plate has a hub solid mounted to itself, not to a clutch disc. Everything I find shows to use a 9 in clutch disc for pto and a 10.5 orc11 in for the trans. The flywheel I have doesn t show in any pics I can find either.
Don t see how the pto can engage/disengage hooked up to the hub in the pressure plate.what am I not seeing?
Disc looks to be 10.5 in 9 spring plate flywheel has number stamped 31218411
Could this be the wrong clutch or.
Thanks for any help!
