Good ol' AD3.152 -
I'll start by saying my diesel experience is nearly non-existent but I'm not unaware of how the concept works.
This tractor ran last in 2023 - it simply won't start. The injection pump was replaced 2 or 3 years ago and it did run reliably since then. I've pulled the hood, the tank and replaced the injectors, which were likely original and very crapped up.
I've bled the crap out of the system, have fuel at all 3 injectors and yet it doesn't even try to fart, sputter or cough. The smallest shot of ether and it pops right off and then dies. Even if there was some air in the system, I think it would have at least tried to do SOMETHING.
I've checked that the stop rod is all the way forward just to be safe.
The fuel return line on the left side (from the seat, looking forward) that runs from the filter back to the tank has a pinhole and will spray fuel when cranking and drip fuel for quite a while afterwards. Is there a chance such a small hole could either bleed off pressure or suck enough air to cause a problem? Either way, I'll need to cut the line and see if I can install a union or have a new line bent up. I don't think the line is available new from anywhere, but I don't have the parts diagram, either.
I don't really want to try a pull-start on it and it's tucked away where I can't pull my truck in alongside to chain two batteries together, but it seems to crank plenty fast. This tractor has normally been a split-second fire even in winter. I'll admit, I'm not super familiar with it, but gramps uses it to mow and blade snow in winter, but he can't really sit out there for hours messing around with it after his stroke.
I'll be happy to hear any input y'all have. Thanks in advance.
