Harry in Ky
- Location
- Central Kentucky
If you are lucky enough to get at least two injector lines loose at the injectors (which you WILL need to do even if you pull the pump for repair) you will only see small pulses of fuel up there with each stroke. It will NOT be a high pressure squirt as some might lead you to believe. If you see anything consistent at all up there, the pump is probably working. If the engine is running and you crack one you will see much more pressure and flow, but merely cranking with the starter you won't see much.
Sometimes you need to bend a 5/8 wrench or two in order to get the nuts loose up there without removing a lot tinware or moving fuel tank.
