MF 165 Hydraulic remote add on / trouble getting it off
051
In my Brother's scrap yard I found two 165's with the added Hydraulic remote control valve body. So far I have not had any luck getting either off. I want to put one on my 165. I believe there are two bolts holding it on. The bolts are recessed in the body. I think they should be allen head bolts, or cap screws. Problem is I don't see an allen head down in the hole. There is something similar but I don't find any flat sides and the hole in the center is way too shallow. As I mentioned there are two of these, each has two holes and all of them look the same? What am I missing? I have tried allen wrenches and torx. I have scratched around in the hole to see if I can knock some rust out but nothing helps.
You're right on the two allen head bolts. Sometimes (and this might be one of those times) the answer is to drill down into the bolt heads until the head is gone then lift the valve straight up/
