AnarchyAcres
I finally got my MF 165 pto clutch to disengage this week, after adjusting the actuating bolts through the inspection plate underneath the tractor. By setting the gap to around .040, the pto clutch now disengages with the pedal about 1.5" off the plate. This is the first time I've ever had a working pto clutch on this tractor. It's very sensitive, just this one tiny spot (1/2" of travel, or less) where the pto disengages. If I push the pedal down further, the pto re-engages. If I open up the gap to .065, the pto will not disengage at all. ( I tried all kinds of settings, which was a miserable way to spend the afternoon!) The main clutch engages about 2/3 of the way up, so I think that the clutch linkage is adjusted correctly. I plan to run it this way next season and hope that things improve. Is it normal for the pto clutch to be so sensitive, or is something else out of whack? I'd appreciate any advice or ideas.
