Jimmy Herring
Hello,
We have a 1982 MF 245, Orchard Tractor which has power assist steering. The pump on the right side and there is a Power Steering Cylinder on the left side with two lines running form it to the Steering Column.
One line is a pressure line an done a return line.
I need to replace these two hoses. Both have a normal swivel connection on the cylinder end but then they connect to steel hose.
The steel end of the hose is what connects to the steering column.
There is no way to disconnect the rubber hose from the steel hose part.
It appears to be compressed on the steel hose.
I have tried hydraulic shops but so far no one can do the connection to the steel hose part and I am told they can not make the steel hose part for me.
I can not find these two hoses listed in the service manual either.
Does any one know a work around or where I can get the hoses?
Thanks,
Jimmy
Thanks,
Jimmy
