MF 255 Power Steering Problem
skycarp
I am working on a MF 255 that I am not familiar with. The steering is terrible. When I turn the steering wheel it makes several revolutions before the wheels start to turn. This is seen as very sloppy turning with the inability to steer without using the alternate braking system. I am just starting to work on this problem so any help would be appreciated.
Steering cylinders need seals turn it all the way one and keep turning wheel, works best when is cold first startup, if seals are blown cylinders will get warm or hot where piston is on end of rod
You can order kits or if you have seal place around you can take apart and have them match them up
