Hi all,
(Apologies for the long post)
My 265's tachometer stopped working recently. Disconnectng the cable, I spun the tach by hand, so the tach itself should have been fine. Removed the tach drive motor (?), and found the gear had separated inside. Tried JB Weld to repair. Put it all back together and it worked for 10 min. Ordered and installed a new tach motor, connected the original drive cable, and nothing. Want to change the cable now, but access is an issue. I have removed the hood but the cable is behing the fuel tank, and my tractor also has the ROPS cab.
Is it possible to get the tach out of the dash without removing the dash cover that goes under the ROPS?
