I purchased a MF 285 a few months back for pasture work and just acquired a Bush Hog 3210 10' pull type cutter. I have not used the PTO on a tractor in 45+ years and have a lot of respect for them. Out of a desire for personal safety and correct equipment operation & protection, I would appreciate any pointers or suggestions before I put the cutter to work. I have read several forums discussing the use of rotary cutters as well as the operator manuals for both the tractor and cutter, but would like to hear any tips from personal experience.
In addition to any operating tips, some specific questions are:
- Overrun coupler? - the tractor's manual says that "The power take-off system operates independently of the Tractor transmission." I assume this will eliminate the risk of the cutter pushing the tractor forward when disengaging the PTO, however, is an overrun coupler needed to reduce wear on the PTO system from the wind down of the cutter after being disengaged?
- Drawbar extension / replacement? - the cutter's manual says 14 inches is needed from the end of the PTO to the drop pin hole in the drawbar. The current distance is about 10 inches. If a overrun coupler is added that will shorten the distance even more. What are my options to correct this problem?
- The tractor does not have a cab. How likely is it that the cutter will throw debris forward and up? Suggestions on how to protect from this? Note: the cutter does have safety chains and the fields were cleared, plowed and planted in grass so they should be free of debris. Also, I will keep the mower high and out of the dirt.
