MF481 S/N 4814400071
2002
8 Speed Shuttle
Mechanic replaced clutch 6 months ago.
Hard to shift into gear now, when you shift it into gear with the clutch pedal down in engages and moves. I have it in 1st so it is slow. Do not seem to be able to engage the PTO.
The clutch pedal is not in spec. It is to be 6.5-7.5” off the floor it is probably and inch more which should disengage the clutch more.
So now I wonder if the lever is not installed correctly on the cross shaft or if it has moved. I think I read that the lever should be loosened from the cross shaft, the cross shaft turned CW until it stops and then with the cross shaft in this position ant the pedal 3/8” off its stop tighten the lever on the cross shaft.
Thoughts?
Something worse wrong? Operator :-(
2002
8 Speed Shuttle
Thoughts?
