Mf-65 gas leaking hydraulic fluid
Rkh
My 65 year old mf-65 gas tractor is leaking hydraulic fluid from the vent hole underneath tractor. Is this a rear main seal & what is involved in fixing it?
It could be leaking from this spot. Is this normal-is this been welded or JB Weld?
This is a MF 6 speed....(3 forward with H/L range)
NO Multi-power .
OIL SEALS had to be replaced on the Transmission and PTO input shafts.
IF the OIL SEALS have to be replaced......this is NOT a task to be undertaken with out a SERVICE MANUAL..
However,your Tractor,your $$$$$'s.
It's definitely not leaking around the 2nd picture-it's leaking around 1st picture with the little hole.
If it is hydraulic fluid, it is from the transmission. Check to make sure the transmission is not overfull.
