DavidP,South Wales
Hi, I believe that either the same or very similar 4wd front axles are
fitted to MF/Iseki and Kubota 25-40 HP compact tractors and perhaps
more. In the last 30 years or so I have rebuilt I think 6 Kubota hubs
and 1 MF. Naturally Kubota will not acknowledge that there is a
weakness in these axles advising that the front end loader should be
removed when not in use. This is not sensible when the loader may
be required every other day. I have been to a Kubota L5040 today
and found that the inner stub axle bearing had collapsed for the
second time in the tractors 1900 hours. With a small but significant
amount of wear present the other side was stripped. Inner bearing
collapse was total with a broken outer ring. I may be able to salvage
the hub but its likely that a new stub axle will be required. Clearly the
is a fault in this type of axle and Id like to hear from anyone who has
had this problem with either make whether very low or high houred to
gain an idea of just how widespread this problem is.
Thanks in advance.
DavidP, South Wales
Thanks in advance.
DavidP, South Wales
