Good evening all,
I'm having an issue with my MF202 being stuck in 2nd (I think..). I removed the fill plug and see the square bolt piece (and the gear below) move forward and backward about 1/4" as I move the stick - which as well only moves a tiny amount. The large gear at the front is all the way forward - does it control only reverse or both reverse/1st? Could it actually be stuck in 1st now maybe? I've had issues with it being stuck in Reverse and can correct that. I recall maybe being stuck in 2nd before but it was a long time ago and it took quite a while to get it out. Things seem pretty solid as far as prying on the rearward gear you can see from the fill hole. Any suggestions would be greatly appreciated..
Paul
Paul
