olgentdc
Man , that was aggravating to do ,,.. And It is Finally done and working right LIKE IT SHOULD ,,. I removed the fender raised the axle 6 inches and sat on a bucket ,, I used a PTO shaft to turn the pto to locate the SINGLE pin on this 730 Comfort King 8349335 1968-69 yr build. I learned it was not a counterclockwise titen style after i spun the cussed collar about 6 notches , ,,. So I gave that up and schemed on How to tihten Clockwise which will be a pain to anyone that has never done this ,,. So This is what i did , Workingthru that miserable small hole ,, after locating pin and rolling it up to 12 oclock position , i placed 2 6 inch 3/8 extensions together with the base on one of the tripods for the spin collar , the extensions were wedged against the inside of the hydrulic levers and would stay at that angle while i tapped the end of the extension with a hammer ,,..while SIMULTANIOUSLY holding the pin forward ,,. Once the collar moves a bit you can relax the hold on the pin , continue tapping until you see the pin drop in ,then repeat by rotating pto to 12 o clock again , disengage
PTO ,get down in that position that big guys cant do easily and tap the extension again while holding the pin out ,,,. . I had to do this at least a dozen times ,,. THERE are no Lor R anywhere to clue any poor mechanic working on thiss tractor which way to go ,,. The book was helpful , But grossly optimistic of stating that this is EASY to move by hand ! ,,. I had to use a HAMMER ! I have adjusted a dozen or more of these type of clutchs over My last 55 yrs.. And I must say this one was the worst one i ever beat .
