ZinMN
friend found a MM bale master PTO baler for $900 complete has been sheded all its life only missing pto shaft good deal or what are they worth
Good balers run from $4-500 on up. I would be careful to find out if you can find repair parts easily on MM - (I don"t know!) You can be sure of breaking pickup teeth, needing knotter parts, and possibly needles sooner or later. Other parts too!
That baler should only be used at antique machinery shows, very scarce, parts would be vary, vary scarce. And I am thinking wire model and the wire rolls of size needed will be very hard to find, acording to the archives there is someplace that is rerolling the new large rolls to the small size to fit the old balers. As I said not for farm use, just show use.
