I finally got my U302 back together and everything seems to be working properly. My only concern is that when I put the tractor into low range there is some gear noise coming from the ampli-torc. The ampli-torc low range on this tractor has not worked in probably 40 years (sprag was damaged and it has since been locked into high range until now) so I am wondering if this is normal since the gears are now running against one another in the ampli-torc and have just not worn evenly against each other due to lack of use over the years. Would this make sense OR does anyone know why I would be experiencing this gear noise?
Thanks in advance for your assistance,
