mm uts ttx 24 carb adjustment
4160
hello..ive a 41 red nose uts and has a marvel schebler ttx 24 carb..is the idle screw turned in or out to lean or richen it?? also if I don't catch it right it wets the spark plugs up on firing it up?? is there a reason for this???
Same setting as later Marvels. Idle/mix 3/4 turn and main jet 2 -2 1/2. Only use Autolite plugs. Champions will not work. Solid copper plug wires if still has mag.
