LUCKY ONE
LOOKING TO GET MORE FUEL OUT OF MY 560 D. PUMP IS MAX OUT ON FUEL WITH STOCK HEAD . PUSHING AROUND 130 HP RIGHT NOW WITH A TURBO
What are your numbers on the injection pump? You need a bigger head/rotor for pump as well as bigger injection lines and lazered injectors. I can get you names of guys if you need them for parts suppliers.
631, that should be 6 cylinder 31 head/rotor. They made a lot of different ones but if youre only going to tractor pull it and youd like the most power, go with a 39 or 45 head/rotor. There are some problems with seizing pump shafts on the 45 head/rotor, but if you size the injectors and lines right, you shouldnt have as much trouble. Call JP (In Indiana) at 812-243-8305 .
