It is 99% leaking from the rear pan gasket and probably a slow drip from the rear main.
Order the AGCO genuine pan gasket kit, the cork is better than anywhere else. I did my pan gasket first, as I thought it would be easier. 3 years later I finally got the courage to do the split and did the clutch and rear main. If you do the rear main, order the rubber rope to lip seal conversion kit. It's pricey but will not leak.
Everything you need to do any job on the tractor is already on the Internet . Bundy bears shed on you tube turns every bolt on the tractor. Here's a picture of my rear main with new seal fitted.
