MarkWisconsin
Hi, Another issue with the NAA Ive been working on for over 6 months. Wish I knew how to list photos to show the progress. Its coming along but as soon as I get one issue resolved I get another one. I got the hydraulics prime to go up before I painted it although I dont know how good because this tractor is new to me. It does have a vane pump which I removed along with the lines for painting. I also cleaned out the hydraulic sump with diesel fuel. Put everything back together and added fresh universal hydraulic fluid. Finally got it primed by putting air in the the dip stick hole. However next time I tried it I loss prime again. Air bubbles are in the hydraulic oil after I get it primed and runs a while. Then after it sits overnight the hydraulic oil clears up. Does a weak pump produce all the air bubbles or do I have a leak where the pump is sucking air. Is that even possible. Can someone from the group give me some ideas. Thanks Much Mark
