lmnop
- Location
- Christchurch, New Zealand
Greetings from New Zealand.
I have recently acquired a locally-built 1970's rough terrain forklift. back in those days imports to NZ were severely restricted and this forklift was manufactured from welded plate steel (some inch thick, some 2 inch thick).
That's an archive photo of one when new.
I got my one cheap as it had steering issues. I've been learning a lot about truck suspension while repairing it. Someone had welded a 3/8" plate steel cage to the rear and filled it with flatten lead pipe in an attempt to increase lifting capacity.
Unfortunately this had exceeded the weight capacity of the rear steering equipment collapsing a kingpin thrust bearing and causing the hydraulic steering ram to bypass it's seals. This turned out to the front steering hub etc from a british Bedford TK truck. I repaired all that and now the forklift is useable and very handy.
I want to protect my investment by keeping the engine/trans in good repair. With the help of an industrial equipment forum, the running gear has been identified as a Ford Industrial Tractor with select-o-speed trans (all mounted backwards, of course). I'd like to know exactly what model so I can get some service info.
I've been told the rear axle has "wet brakes" that require a specific transmission oil "tractor fluid" and that the mystery pedal on floor on LHS of my steering column is a diff lock.
I note that a transducer coming out of the top of the gearbox close to the sawn-off gear lever (!!!) appears to have been bypassed by taking one wire off one terminal and shorting it to the other one. I'd like to know what that is. Pressure transducer?
Some photos follow, and here are the numbers I've managed to snaffle off various locations:
438
6L25
*B295236*
casting
J122F(?)
Head castings:
T3
6E 5
D5NN6090-K
Inlet manifold:
D5NN 9425J
Transmisson casting has the following numbers:
D3NN7006C
Stamped:
BG42B21-438 L19(F?)
One other thing I would note is that there is a very loud whine coming from somewhere in the transmission that's so loud I wear earmuffs while using it. Comments?
Thanks in advance for any help!
438
6L25
*B295236*
casting
Head castings:
T3
6E 5
D5NN6090-K
Inlet manifold:
D5NN 9425J
D3NN7006C
Stamped:
BG42B21-438 L19(F?)
