Hey guys, I'm restoring a pedal tractor for my sons for Christmas. It is the more common Ertl model #404 that is in the style of an IH 86 series tractor. I've taken it all apart and have sandblasted all parts except the main body halves. Still have those to do. Not sure what this is made of but it appears to be cast of aluminum or pot metal. The rear axle housings seem to be cast out of aluminum.
My questions are about prepping, priming, painting, and clear coating the parts. I want to do it the correct way so the finish looks good and lasts for years. With the plastic parts, I'm going to clean them, scuff with a scotch-brite, use an adhesion promoter, then paint them semi-gloss black. With the steel parts (shafts & linkages) I'm bead blasting, spraying with sealer primer, spraying with filler primer, painting acrylic enamel with hardener, then clear coat.
What is the proper process for the cast aluminum and/or pot metal ? Planning on bead blasting those parts first and my thought was to use the same method as the steel parts. Didn't know if I needed to prep or use any other products with that type of metal.
