TheBrokenFarmer
Been changing the hydraulic fluid on my Deere 2010 RU SN 65635. What came out was about 10 gallons of watery milky sludge oil when I took the 8 inch long filter out and the two drain bolts.
I thought I’d add it in to the 3 or 4 inch diameter inspection port, about even with the brakes on the right hand side of the tractor. What I think is the conventional hydraulic fill port has what looks like a high pressure 90 degree fitting on it and this seemed easier.
It only took about 4 gallons before it reached the level of the port. I expected a whole lot more.
Was the not an acceptable place to refill at and does anyone know what’s going on?
Lastly, there is this metal tab under the machine, near the forward drain plug that is dripping out the new fluid. What is this thing?
The fluid I’m using it the universal traveler stuff from TSC.
Thanks in advance
Inspection port in front and high pressure 90 behind.
And
Spinning metal tab that’s dripping ahead of the forward drain bolt.
John
Thanks in advance
And
John
