down_right
I am in need of a better ignition key switch for my Farmall 826 diesel tractor. I have bad experiences with oem key and button ignition switches always breaking. I heard COLE HERSEE is a good brand for heavy duty ign switches for tractors, but there’s a lot of options to choose and I’m not sure which is right when factoring in the various accessories I have on the tractor.
I have (or will have) the following lighting/electrical parts installed on my tractor:
Once I have the switch, my plan for wiring the above was something along the lines of:
A) wire in the ignition switch (I am using a 63A internally regulated/one wire alternator)
1a) 10 awg wire from alternator to BAT post on starter
2a) 4/0 awg battery cable from battery positive post to starter’s BAT post
3a) 10 awg wire from starter’s BAT post to ignition switch’s BAT post
4a) 10 awg wire from ignition switch’s START post to the START terminal on the starter solenoid
B) wire in the fuse block for powering accessories & lighting
1b) install fuse block somewhere to tractor’s firewall (probably the empty area under steering wheel)
2b) run 6 awg wire from POS post on battery to the positive on fuse block
3b) 6 awg from NEG battery to negative on fuse block
C) wire in lights
1c) 20A (or 30A?) fuse with 12 awg wire to line on the power on/off switch for lights (all of them are powered by one switch as they are LEDs, unless so should split it between two?)
2c) 12 awg from switch to load to power the lights
3c) 12 ground from switch to neg bus on fuse block
4c) lights grounded to frame, 12 awg
D) ether solenoid/switch
1d) 12 awg from fuse/pos to oem ether switch (20A fuse)
2d) 12 awg from ether switch to solenoid spade terminal #1
3d) ether solenoid spade terminal #2 to ground with 12 awg wire
E) usb charger
1e) 10A fuse, 14 awg wire from positive fuse block to hot spade terminal on charger
1e) 14 awg wire from negative bus to negative spade terminal
F) blower motor/windshield wiper
These already each have their own inline 20A self resetting circuit breaker, could this just be connected to the accessory post on the ignition keyswitch to prevent battery drain vs just connecting directly to the battery?
G) voltmeter
Should this be connected directly to battery or also to the accessory post on ign switch? I’ve read it’s better to go directly to battery sometimes, but then it’s continually draining the battery?
H) fuel gauge/sending unit
Never had a working one of these on any of my older tractors. All I remember is reading about needing to be careful about connecting it to the correct wire (either the light blue, NOT the dark blue, or vice versa, based on OEM wiring scheme) or else it’ll get fried.
So…I don’t have a clue how this would factor into my electrical configuration.
- 12 Volt Fuse Block Box (100A max for panel, 6x circuits with 30A max each) I will use this to protect lights/accessories. Currently I have inline 20A blade fuses to protect the ignition/ light switches, usb-c charging port, etc. the wiring under the dash isn’t pretty and requires a lot of forceful stuffing of wires whenever I bolt the panels back on and I want to change that
- 12v USB-C/3.0 power outlet: charging phone
- 126w Light + 4pcs 18w LED Pods: replacement for nnalert halogen lights on tractor
- OEM blower motor/fan for the year-a-round cab. Don’t know the specs other than that it is on one of those self resetting 20A circuit breakers that is bolted to the frame
- Windshield wiper motor. Same as blower motor, but it has its own 20A breaker.
- Ether solenoid button. Currently using OEM as I’ve never had an issue with it. Unsure of specs/amp usage
- 12v digital voltmeter
- Fuel gauge & sending unit (aftermarket from YT); PN: 107954 & PN: 121190
- Universal aftermarket temperature gauge PN: 186993
C) wire in lights
E) usb charger
G) voltmeter
