Not sure about the generator grounds but using the neutral as a ground may be better than using an alternate ground. I've heard some furnaces won't run with an auxiliary generator until the ground and neutral are bonded together somewhere. There are lots of dryers and ovens wired that way to the older standards. The separate ground wire may be safer I guess but I don't think it's a dangerous situation if it's wired the other way.
Howdy again David fyi for others here. Grounding and bonding if a genset is similar to utility wiring. Iffffff it’s configured as a Seperate Derived Source it’s n is to be bonded and connected to a grounding electrode Sams as utility. However if not and there’s no neutral switching and it’s n and g are connected to the hones n and g like most do, no ground rod is required and the genset n should be floating. Sure it can still work otherwise.
I agree some modern devices won’t work if there’s no n g bond
Yes a proper EGC is the best path for fault current in a bonded system,,,,,yes other current paths might still work if low enough resistance and still wired proper. No it’s NOT best to use neutral for fault current even if it works z(a whole orher thread) and for sure Mother Earth alone is not a good fault current return path as it’s too resistive.
I’m sure you get all this but it may help others. I believe a this is still true but codes chenge so no warsnty. See if the other fine engineers and electricians in here agree ???
ps. There can be ways a bootleg ground is unsafe like if you attach the washer or dryers outer conductive metal frame to the neutral I tending it to serve as an EGC,,,, it becomes like the neutral a hot live current carrier. Say meybe one hand is on the dryer and another hand on another path back to the energy source And remember the neutral is a grounded conductor ,,,, say the neutral is carrying 15 amps,,,, say your two hands create another alternat path to carry return current ,,,,it only takes like 0.050 amps to cause the heart to fibrillate. That’s why I don’t like bootleg grounds snd attaching the dryer case frame to neutral.
Notice how the hot and n wires are insulated ??? Would you strip the insulation and touch one hand to it while standing in the bathtub ???
Yes bootleg grounds csn work but I’m not a fan of it. However I support anyone’s right to do as they pleaee
Note this is not perfect all right or ideal I can’t explain a lifetime of practice and the nec here in a few sentences. This is only my belief and opinion and people should not take my word for any of this where life safety is concerned consult the nec and professional engineers and electricians. I bet the engineers and electricians might agree with the above but if not I’m willing to learn
God bless all
Here be safe !!!
Ps. Yesss the old dryers worked !!! I’m only saying I prefer the later 4 wire systems with the frame connected to the EGC and don’t like connecting the frame to the hot live curtent carrying neutral. The neutral is insulated for a reason and I don’t like bonding it to the outer metal case frame if an appliance you touch !!!!! but that’s just me yet support anyone’s right to do as they darn well please yayyyy
Take care nice chatting with you sir
John T
