Tgrasher
- Location
- South Southern illinois
Everything works as it should except that the hydraulic cylinders will not unlock and lift the gate. Got it to work by bleeding a little oil out of the top fittings on the lift cylinders. Was able to cycle the door up and down a few times and then it will quit. Lift cylinders start to lift and stop working. Tractor is a White 2-135 and hoses have been switched every which way, and they jerk when the lever is pulled. Bought this baler at an auction a week ago and this is probably why the owner sold it. Manual doesn't help, just says inadequate hydraulic pressure, but tractor will easily lift a heavy disc. Thanks for any ideas on this problem.
