jon f mn
They did, frost was near 12" deep. Their auger went right through it with no problems.Kind of surprised they didn't have to battle frost to set the piers.
Vito
Vito
They Finnished my new shed yesterday.
View attachment 100092View attachment 100093
Was surprised to find the doors were framed with steel. Builder says it's stringer that way, sure looks good.
Even got the first case in.
Next summer I'll have to fill in to bring the grade up. But I'm excited to get stuff in that needs it.
Very nice, jonf!! You will love it!They Finnished my new shed yesterday.
I had planned on coming too but forgot to set alarm. Woke up 8.15Looks real good you will like the indoor storage. We missed you at breakfast this morning. Maybe next time. Gordy in Mn.
That looks like 2x6 laminate post 7.5 feet on center 14 feet tall.They are under 8' by a little. Snow loading it being ready for insulation required less than 8', I don't know how much less.
I don't plan on it, it's just made for it if I change my mindThat looks like 2x6 laminate post 7.5 feet on center 14 feet tall.
If you plan on insulating it why did they install sky lights ???
I wasn't going to run electricity to my building, but boy is it dark in there! Then I found I was frequently needing to boost something. So just one 20 amp/120V circuit -enough to run a battery charger/starter, plug in a block heater, or illuminate some LED's, did the trick.I don't plan on it, it's just made for it if I change my mind
I don't remember where I heard it, but I always think of this quote when people talk about sheds-"You pay for a shed, whether you own one or not."Jon, my son put up a shop on our farm in 2016, same size as your building 40X60X14, I remember hauling my toolbox down from our old garage on the forks of the 530 I've got drove right in and turned a circle the shop seemed so big. But they do fill up. He also had a 18 foot wide lean to added on each side we use for keeping tractors and equipment out of the weather. There is nothing better than keeping your stuff out of the weather. You will definately never regret putting that building up. Just too bad they have gotten so expensive.
I am curios why the area was not built up and leveled before the building was put up. I would think it would be a real pain and harder to pack up close to the building and will be settling for years under the walls. I have seen sheds that stay like this and it keeps rodents out a bit and air flowing though.They Finnished my new shed yesterday.
Always fun to put up a new building and then get to use it. Seems like it is always too small when you start to put stuff into it! Looks great!They Finnished my new shed yesterday.
I do have plans to run power out there for that reason and some light in the winter. Hope to get to that next summerI wasn't going to run electricity to my building, but boy is it dark in there! Then I found I was frequently needing to boost something. So just one 20 amp/120V circuit -enough to run a battery charger/starter, plug in a block heater, or illuminate some LED's, did the trick.
The builder asked me not to build it up before so it was easier to build. His lift wouldn't have worked on the slanted sides to work on the building. Plus he says loose dirt makes it hard to drill the holes for posts. Made sense to me after he said it.I am curios why the area was not built up and leveled before the building was put up. I would think it would be a real pain and harder to pack up close to the building and will be settling for years under the walls. I have seen sheds that stay like this and it keeps rodents out a bit and air flowing though.
