Cubert
- Location
- Milton Vermont
I am the the next owner in line of a Oliver OC3 crawler with a loader bucket and have little idea on how to trouble shoot my current issues. Maybe someone has seen this issue and can help point us in a good direction.
The machine starts up without issue and the throttle can somewhat power up the engine but after a few minutes of running the oil pressure gauge drops to 0 and I think I start hearing a little knock, this could be the engine running ruff at high throttle.
When cold it will move forward and backward ok, and will climb a small grade but once it warms up it starts stalling when trying to move it on flat land.
I have gotten a few good ideas to go check reading the following forum post
forums.yesterdaystractors.com
But I dont' think its the same issues as oil pressure is also a part of the issue.
I did notice that the oil filter was missing the center oil tube that goes up into the oil filter, I have ordered one from olivercrawlers.com to repair this issue. I also read in service manual that oil pan should be dropped and cleaned out every 500 hours. Any one ever seen a oil screen or oil pan issue causing pressure issues?
Oliver OC-3 crawler
My neighbor and I just bought an Oliver OC-3 crawler that has been sitting for a few years. It is equipped with backhoe and it runs from a Hercules four piston gas engine. We got it to start while cold, but when it warms up the engine dies and it refuses to restart until it completely cools...
