Oil pressure gauge MH 22
Gtidwell
Can I just buy any gauge to replace mine on a 48 Massey Harris 22? I was wondering if I could buy a generic set, sending unit, line, and gauge to replace it?
You can use a generic gauge. You have a mechanical gauge so there is no sending unit, it used fittings and tubing between the port on the block and the gauge.
If you are getting one with numbers don't get a range that goes way above actually pressure, I will guess a 0 to 60 psi will work.
22's only carry 20lbs of oil pressure. You don't want a gauge that reads over 30lbs. The needle will barely move with a 60lbs gauge in there.
