oil pressure relief valve
Pembroke
Location
Mt Washington KY
YT IH forum: oil pressure gauge pegged out. Reply was, oil pressure relief valve may be stuck. Ended up that was the problem. On My gas Case 441 gauge will peg all the way over high side. I'm looking for where relief valve is located. Only place I can see is between starter and oil filter there is a place that it might be. Please help as I would like to be able to locate and fix. Thanks. Pembroke
30 PSI is great!! Before you tear into anything, take a reading @ the block w/ a 0-60PSI gauge and see exactly what you have.
Take a pressure reading at the block oil gallery as others have advised. My guess is you are OK. I installed a 930 oil pump on an 830 when the balancer broke off. Pressure relief was stuck on the 930 pump. When I started it the cannister oil filter blew off and flew about 50 feet. Stripped the threads right off the bolt.
