Sturdily7974
I am working on the magneto for my Oliver 70. I worked on the tractor about 15 or so years ago, purchasing new parts, etc. Well it sat without being finished until now. So far I have not had it running. Currently I am making sure the magneto is timed and putting out good sparks.
When attaching the magneto to the tractor, the drive coupling is not perfectly horizontal. The manual says to match the red tooth on the small magneto gear to the white line on the larger gear. The small gear has a raised tooth but just one tooth before that there is a red paint dot. Well I cannot attach the mag to the drive coupling with the red tooth pointing up, only the raised tooth. I'm not sure why the manual mentions a red tooth when the drive coupling would have to be less horizontal than it is now for that tooth to be accurate.
The mag fires on number 1 just a bit after the white Ignition / Gas timing mark passes by. I'd say the timing is dead on because the piston isn't fully up yet when the timing mark is visible, so just after should be good. So the raised tooth has to be the correct alignment.
I seem to be getting a spark on the number 1 plug when the mag gear hits number 1 and again on number 2. Number 4 never sparks. I've had the spark plugs out and resting on top of the holes so I can see them sparking when I use the starter. 1 and 5 are consistent but the others don't seem to be firing very often.
When hand cranking the magneto, I cannot see a spark sometimes on any of them. I do hear the audible click from the magneto on every fire. But when I crank with the starter and then afterwards go back to hand cranking, the audible click is missing for some time and then after several rotations it's back again.
I'm not sure what all this means but I am going to make a small spark plug wire and purchase a spark tester so I can test close to the mag. Maybe this will tell me if they are all firing or not. The points are gaped and cleaned. I've done what I can except for taking the whole magneto apart and cleaning it up. Not that I want to do that if I don't have to but I cannot find parts for the MJC models online and I don't know of anyone around here that works on them. Sending it out would be expensive too with shipping both ways.
I thought about converting it over to a distributor but since I cannot find the distributor housing assembly that would mount to the tractor, that is also never going to happen. https://www.tractorpartsasap.com/distributor-remanufactured-delco-remy-1111412-205103.html This would never work without it.
I have read that these magnetos are just weak overall. Perhaps it is sparking as good as it ever will and I just cannot see it every time. Should I move on to getting the carb ready to fire and see if it will turn the engine over or keep working to get a good blue spark before moving on? It just doesn't seem like there are as many parts available online as when I first started working on this tractor. I hope I don't run into any more surprises before I can see it running.
