MistGreen880
I am currently working on pulling the engine out of my Oliver 880 Diesel to overhaul it. It has a PTO and a Power-Booster. I read in the book that you have to pull the PTO shaft out first, and I'm wondering the reason for that and any tricks to get it out as mine seems to be stuck. Also trying to find out how to disconnect the power booster from the engine to remove it. I tried pulling the engine forward off splines and it went about 1" then stopped. I also heard that two engine mount bolts are different from the other two. I have one with a 13/16 head and three that are 3/4, is there anything special about the larger bolts? I've read the book and can't figure out what is going on here and why I can't just slide the engine forward off splines and lift it. Am I supposed to remove PTO shaft and unbolt the power booster and lift straight up?
Also, on the power booster, is the lever supposed to snap over center and pop in? Because mine just kind of goes forward easily makes a hollow thump against the clutch and doesn't seem to do anything.
Any help is appreciated.
