Quailman84
I've got a 35 diesel I'm in the process of installing a new short block. The old engine ate up the crank and block due to a previous rebuild apparently done without one set of thrust washers. So I got a new short block and it has 0.025 or 0.026" of crankshaft end play. It's it ok? I can't seem to find a spec for end play for the A3 in the MF 35 service manual, but the AD3 version specifies a max of 0.015 inch. Are they the same? I can get 0.010 oversize thrust washers but that's still going to leave it at 0.015 to 0.016 unless that's .010 each side. Any help is appreciated.
