I have recently rebuilt a 2N pump and shortly after installing it I found a leak near the test port. The mounting bolts were tight, so it didn't seem to be a leaking gasket. I thought that I might not have tightened the plug well enough, since I don't like to over tighten plugs. It didn't feel tight, so with a load on the lift to put some oil pressure on the leak, I snugged it up. It leaked faster. I snugged a little more which opened up the crack enough to see the problem.
This You tube video provides a good picture about 13 1/2 minutes in. The crack in the video is nearly identical to the one in my pump. The solution in the video was to have the crack TIG welded. You tube video showing TIG repair at 60 sec
My question is whether it might work to sleeve the hole with a threaded stainless steel tube without welding the crack.
The picture shows the crack location and a drawing of the stainless steel sleeve available from McMaster.
The crack is only loaded by the hydraulic pressure and the wedging action of the plug, which is probably worse than the hydraulic pressure. The sleeve would extend into solid metal , so the crack should not be under any load after the repair.
I would drill and tap 2" into the hole, then drill out the last half inch so the hollow tube would extend well past the crack. The tube would be cut off and threaded internally for a plug. The wall is too thin to thread the ID where the OD is threaded, so the plug has to be more than 1 1/2" from the end of the tube. The oil passage up to the pump would have to be drilled through the tube after installation.
This post was edited by Dave G9N on 12/26/2023 at 09:15 am.
