Putting Oliver 770 sheet metal on an Oliver 88
Hello all, I have a Oliver 88 that I want to put 770 sheet metal on. Everything lines up right until I get to the 88 radiator and nose cone. the issue is I haven't figured out how to connect the nose cone hood and radiator together. And I was hoping you guys might have some ideas. Thanks
Is the 770 sheet metal shorter then the 88? It looks like you may have to build some sort of a support to mount the nose to, maybe sheet metal 1/8
thick plates. one side bolts to the radiator support and the other to the nose to fill that gap. ( picture #2)
From what I have found the 770&88 sheet metal is pretty much the same. But the 88 had a nose cone that wrapped around the radiator and bolted to the front of the frame.
