We are restoring a 1943 Farmall H and have this chunk missing in the case. According to the service manual, this case is "gray-iron casting." Searching online some people braze, some people weld. I have not welded or brazed cast iron before. I have an oxy-acetylene cutting torch, and several welders available including SMAW, GMAW, FCAW, and GTAW. I'm thinking it is best to braze this based on what I have read so far, but would like people's advice. Most people say to preheat, but some say that it is not necessary. The case is completely bare right now but obviously is too big to fit in an oven. There should not be pressure on this part of the case, and it is not structural. The bolt was actually still tight and unthreaded from the hole. I assume water got in the bolt hole and it froze and broke the piece off. I do not have the piece that broke off, the entire area would need to be built back up to get it to look correct. This is a high school restoration project to be used at competitions. It needs to be a good repair. What do you recommend?
