DoubleO7
- Location
- Crystal River, FL
That is a good idea. The bolt still had to be turned to remove it from what is left of the casting.(quoted from post at 02:31:38 11/21/23) Or put a stud in, and epoxy over the whole thing. Pretty easy to screw a nut on the stud and finish it off with a file and a little epoxy on the top to look just like a bolt.
If the O.P. Is worried about how much torque it might take to pull the stud out, he could, install the stud and epoxy. Then down towards the end of the stud, cross drill thru the epoxy, stud and remaining cast iron and then install a spring pin.
Then the stud would not turn out.
