I have a 1974 Case 444 that has the hydraulic valve and hose connections for tiller (I think) on it. I do not have a tiller though and have never used this connection or valves. This Case also has a front blade, which is what I've mainly used it for and hauling a lightweight horse manure cart to the compost pile.
I'd really like to use this garden tractor to pull a light weight (DuraGrade, so ~36 inch wide weighing about 500 lbs---so ATV sized) rock picker, but to do that I need to connect the hydraulic cylinder on the rock picker to the hydraulics on the CASE so the forks can be raised or lowered. This is a 1/4 inch hydraulic line with about 2 foot of cylinder travel give or take a few inches.
Are the tiller hydraulics 2 way (with up and down pressure---ie a tiller can run forwards or backwards)? If this is the case, I can raise and lower the rock picker forks. If not, do I need to add a 2 way spool valve to the connection from the tiller valve or am I way off base in thinking this is even possible? I have not been able to answer that question with any information I've been able to find.
Thank you.
Thank you.
