When looking over the rear mount for the rocker on my recently acquired 8N, I noticed a bushing inside the housing the pivot pin passes through. Though I'm new to the 8N, I'm pretty confident this busing isn't original as I can't find it on the parts diagram nor have I seen this busing in any photos, and I've looked at a lot of them. The unit is an early 50's model so I believe it uses the short pin that only fits though the inner mounting ears. The bushing has a slight shoulder on one side, no shoulder on the other end, is split along the entire length and is made of steel. Please see the attached photo, the bushing shoulder can just be seen inside the red circle. Has anyone seen this before?
I've fiddled around with it a bit and clearly it's going to be a real challenge to remove. I've lubricated it liberally with penetrating oil, applied reasonable heat on the housing and using a drift from the left side I haven't been able to get it to move, at all. Suggestions regarding removal would be helpful at this point!
