I am getting close to putting the jugs back on the engine block. While talking to Allen K he suggested maybe putting two gaskets on the bottom of the
cylinders so that when I tighten down the cylinders, the rings wont hit the ridge inside the cylinder. The gaskets from my gasket kit are cork. Im
afraid if I use two gaskets, there might be a risk of oil leaking. The other side of the coin is if I only put one gasket on, theres a chance of breaking
rings. Has anybody else had luck using two gaskets?
