Serial number question
Farrd53
I’ve always wanted to restore an old tractor…. Well here I go!!
I recently bought, what I was told, was a 1959 Ford 641. I have located the serial number and it reads as 43991 with a diamond symbol before and after the number. Above that is stamped 641.
My question is: looking for parts, they refer to serial numbers containing six digits. Can someone help an old man out with this, please?
43,991 DOES appear to be a valid 1958 "641" serial number.
WHERE have you been searching for parts and what parts were you looking for that required a serial # to look up?
Try adding a leading "0" to your S.N., 043991.
Hundred-one series tractors (XX1 models) can have a serial number with 4, 5, or 6 digits. The serial number sequence started with 1001 around September 1957 and ended with 171247 July of 1962. Your number 43991 is September 1958 by manufacture date but may be a 1959 by model year, very close to Ford's model year cutover. My Ford parts catalog goes by model year with rare references to serial numbers.
Wheel bearing kits
Wheel bearing kits
I can see why the confusion. Serial number 137817 is from the prior 600 tractor series. It is a 1957 serial number. Below are the parts book pages for the front wheels. As I read it you should have hub C9NN-1104-F (1957 forward). On the second page the original kit was CBPN-1200-C but was replaced by D5NN-1200-A and D5NN-1215-A. Bearing part numbers also listed. These numbers may have changed in the meantime but this information should get you started.
