will-max dairy
Our NH276 baler went down a couple of weeks ago, with just a little bit of 2nd cut and bedding to go.
Fortunately, a good friend of ours was still sitting on a NH269 in a shed. We had baled with his baler way back 15 years ago, before getting our own equipment. It was good fortune that his baler, after sitting shedded for three years, made good bales with just a little bit of grease and adjustment. So now we're about done for the year.
But... this has me thinking about our future of idiot square making.
The 269 didn't have a thrower. I had an old 36" chute that came with our 276. (We have since put a model 58 thrower on it)
We mounted the chute on the 269 and quickly built an extender out of 2x6 lumber and plywood (screwed n glued... works nice). With the extender, the chute reaches our kicker wagons, so we can bale "old school" with a rider on the wagon pulling bales and stacking with a hay hook.
We also have two flatbed wagons available to us... which... we can now use with the chute. So... chute baling means being able to load four wagons.
I forgot how nice and square bales are when they aren't mangled by a thrower. And, we can make nice, long, bales that lock in nicely in the hay loft.
And... when I'm the rider/stacker... I can do things like... I noticed that my twine splice knot didn't pull through... I called to our son-in-law (the driver) to stop for a second... I restrung the baler needle... but not before I cut three long pieces of twine... I told him to start baling again... I walked along.... and then he clutched and paused three times as the next three bales got on the chute; where I did "the haybuyer's tie" on them to fix the bales. With a thrower... all three of those bales end up in the wagon... you have to climb up there... dig all the loose hay out... throw it off... jump down... straighten it out on the ground.... then circle the whole tractor/baler/wagon shebang around to clean it up...
Also, unloading a stacked wagon is easier than trying to unjumble the bales randomly kicked in by the thrower.
And... we have probably spent 5 to 10 hours of mechanical time on the thrower over the past couple of summers... bearings... welding cracks in 50 year old thrower frames...
And... we are using wooden kicker racks; which, after about six years of baling... are starting to crack and rack and sway... You pay for all of the lumber to make those wooden kicker racks... only to burn it for firewood about 6 - 10 years hence... or... you spend a few grand on steel, welding and paint to make steel racks that last...
I probably won't get an answer here. But I just think it's worth thinking about... there is probably a certain number of small squares per year that "may" be more efficiently done with flatbed wagons, a chute and a rider than with throwers and kicker racks
